Audio 20
Audio 20
hello
on my audio 20, if the balance and fader are positioned on 0, only the left side of the speakers are working
if it is balance 4+ then all the speakers are working.
the central speaker on the dash is not working at all, I removed it and tested somewhere else and it seems ok.
do you thing it is a wiring problem, maybe someone before change something ?
it had installed a parrot telephone system and maybe they didnt install it properly?
I would like to be sure what to find before removing it and checking, if it will be a audio 20 problem then I will try to replace it, maybe with a newer version.
