E-Class (W211) 2003-2009
Catalytic Converter help
Old Apr 6, 2017 | 02:53 PM
THE Rooster's Avatar
03 Mercedes E500, 74 Vette, 93 Mirage River Racer 111mph. in 12 seconds, 94 Lincoln Mark VIII + NOS
Had all 4 cylinders misfire on the driver's side of my 2003 E500, was told that my converter may be clogging up (I have been hearing a rattle for sometime in the exhaust).
Questions:
Are there aftermarket parts available
Would you replace the converters only or do complete new from front to back?
Any advise & your thoughts or links to parts would be GREATLY appreciated!
Old Apr 7, 2017 | 09:22 AM
TTT
looks like I'm on my own!
Old Apr 7, 2017 | 11:35 AM
agm18's Avatar
2006 4Matic wagon Elegance, Infiniti 2004 G35 Sport, 1969 Jaguar XKE (s) 1988 Camaro Convert (s)
Converter
Questions:
If it really is the converter AutoZone has generics for about $100. Check for codes and then use a good muffler shop for the repair.
Old Apr 7, 2017 | 12:43 PM
angelglo's Avatar
Veteran: Marine Corps
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
Just replace the converter. But you also have to figure out why your converter is clogging if this in fact is why you have the bank 2 misfire. is this for your 03? replacing can get expensive depending on where you live. If you live in CA, you will be limited t where you can get a converter which is why I say it can get expensive.
Old Apr 7, 2017 | 01:09 PM
Thanks for the input...
AGM18; I will check local parts houses to see what they offer
angelglo; Yes this is on my 03 E500, I live in small town Kentucky where there are no vehicle emission tests. Vehicle has had a rattle for a month or so now in the location of the CATS. Shop that has always worked on car (replaced my suspension with Arnott spring/shocks, oil changes etc.) ran the codes and said all 4 cylinders on driver's side misfired. I've been considering adding a diverter to bypass the mufflers when I drive it & keep it quiet when the wife has it. Just thinking now might be the time to jump on this!!!
Thanks again for all the info!
Old Apr 12, 2017 | 02:36 PM
Follow up!!!! The back 2 CATS have been taken care of & car is back on the streets!!!
Old Apr 12, 2017 | 02:41 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
When I admire you reporting car back on the road, I have very mixed feeling about polluting report.
Old Apr 12, 2017 | 02:44 PM
I live in a small city that probably equals the population of your block, cow crap smells worse!
Old Apr 12, 2017 | 02:51 PM
kajtek1's Avatar
I own the only house in my block
Population 2
