E-Class (W211) 2003-2009
Replacement of Hood - Require Heavy Duty Lift Support
Old Apr 8, 2017 | 10:16 AM
Fresh101's Avatar
W211 2008 E350 Sedan 4Matic
Hello everyone, I have 08 E350 4Matic Sedan and I have been searching the web and forums and can't find a part number or anything that can point me to a heavy duty lift/shocks that will support the hood that I installed. The lifts that are in place worked fine with the original hood as it's aluminum, but now that I had to replace the hood to a metal one, it's a lot heavier. Now the original hood struts does not hold up and have to use a stick while working on it. Please help locating something that will work or if someone has already gone thru this and replace what part # you ended using? Thanks
Best Regards,
Ralph
Old Apr 9, 2017 | 10:39 PM
Fresh101's Avatar
Anyone?
