E-Class (W211) 2003-2009
W211 4Matic Vibrates when turning at slow speed
Old Apr 25, 2017 | 03:40 AM
Paul509's Avatar
Mercedes E500 4MATIC
I replaced my upper ball joints, axle shafts, outer tie rods, inner tie rods, and my 2004 E500 4Matic still vibrates when I drive slow and turn the steering wheel left or right. It's really annoying in parking lots because the whole car starts to shake and vibrate. Anyone know what this can be??
Old Apr 25, 2017 | 12:41 PM
konigstiger's Avatar
'71 Pinto
Common problem with transfer case, see attachments you can try oil change if this fails you will need replacement.
Attached Thumbnails W211 4Matic Vibrates when turning at slow speed-capture.jpg
File Type: pdf
Old Apr 25, 2017 | 01:20 PM
Paul509's Avatar
Thanks so much!
Hey thanks a lot for your response and the info! I'll look into it after work! Thank you!
Old May 17, 2022 | 06:33 PM
Bela's Avatar
W211 E500 4matic 2005
I have the same problem and we changed all the parts related to the transmission and the problem still exists Did you solve the problem for your car
Old May 17, 2022 | 07:01 PM
Paul509's Avatar
I don’t remember what it was because it happened so long ago, I think it was the transfer case - you probably have to change the transfer case fluid. Really hard to do it, you need to get exact measurement of fluid in there and have a tool with a flexible straw/hose to pump out the old fluid. I did it in the garage and it helped but because I didn’t do it professionally it didn’t completely get rid of it. If I remember correctly, that’s what happened but this was years ago and I don’t remember exact details.
Old May 22, 2022 | 08:59 PM
HardmanGT's Avatar
2005 E55 2005 E500 4Matic
I had issues with that chatter/vibration in tight turns. I tried the fluids flushes and they worked for a little while before the issue returned again. I ended up dropping the front of the driveshaft and unbolting the planetary from the transfer case. The clutches were glazed. I went back to my MX days and tried deglazing the clutches with fine sandpaper. I think I used 500. I reinstalled, filled with fresh fluid and drove around a few parking lots in slow figure 8’s that was 4 years ago and it has never been an issue since.
