Transoil for the 7g
e500 2005
Transoil for the 7g
I got a e500 2005 with the 7g tronic.
i cant find a definity awnser anywhere. Which oil should i use for the 7g? Which mb standards should it meet and how much do i need?
which oil do you guys run?
Received 1,730 Likes
1922 Ford Model T / no OBD
Are you going to service yourself? I hope you are aware there are no dipstick and read up on how-to on doing it. Since it has to be drained out of the pan as well the torque converter, replace the filter and gasket, then filling in through the drain plug along with taking temp read. Hope you read up on the technical how to before tackling that job.
arto_wa (06-13-2017)
Well said - here is a good thread to start reading on the subject:
https://mbworld.org/forums/c-class-w...ce-thread.html
