E-Class (W211) 2003-2009
LED Tail Light facelift Error
Old Jun 18, 2017 | 09:14 PM
W211Virgin's Avatar
2004 E320
Exclamation LED Tail Light facelift Error
Hello,
Trying to swap out the tail lights from a 2008 E350, which are LEDs but after I hooked them up, I get an error code that my brake lights are out.
Also, the brake lights don't turn on.
I heard this was a plug and play...however, it does not appear as so...can anyone advise?
Thanks!
Old Jun 18, 2017 | 09:17 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
it would not work as you thought would be plug and play, unfortunately with MB cars they are fickle with the electrical and they have to be coded to make it work, if you're going from a regular bulb taillight to LED. My 09 E350 has a sport package and I noticed the brake light are LED only and the non sport are halogen bulb, so they are not swappable til it's coded through DAS star scan.
Old Jun 18, 2017 | 09:18 PM
W211Virgin's Avatar
2004 E320
So I have to go to the dealer to get it coded?
Cost?
Old Jun 19, 2017 | 10:47 AM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
The Depo facelift LED units I installed from eBay were plug and play on my 2003 E500 that came with halogen tails from the factory.
Old Jun 20, 2017 | 10:17 PM
W211Virgin's Avatar
2004 E320
Mine are OEM so many that is where the problem is... May throw them on ebay
Old Jun 21, 2017 | 07:03 AM
These are the ones I purchased from eBay seller fishcake. Highly recommended vendor who stands behind his products.
http://www.ebay.com/itm/FREE-SHIP-NO...NRDLbz&vxp=mtr
Old Jun 21, 2017 | 09:44 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I don't have personal knowledge whether coding will make them work but if that's what it takes, I highly recommend you go that route.
If that's not a viable option for you, you can probably get away with adding an inline resistor or canbus adapter on the wiring of each taillight. It's a very cheap procedure and any shop that installs aftermarket HID kits should be able to do it for you.
Old Jun 22, 2017 | 12:12 AM
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
I'm thinking of doing the same upgrade and I believe it will make the car look cleaner than the foggy headlight that make the car look ugly....
Has anyone tried these headlights and are they good ? these are from the seller recommended by @Bahnstormer
Old Jun 22, 2017 | 12:45 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
I will look over the weekend for you when I am working on mine. I will go through DAS/STAR/Xentry and see if the rear taillights are actually coded for LEDS.
(I have a 2009 sport). It wouldn't surprise me if they needed to be coded. Seems like everything on this car needs coded. Did it for bi-xenons including OEM led front city lights(this needed to be done in developer menus), power folding mirrors, tilt passenger mirror, backup camera, flashing emergency brakes...etc.
-Nigel
Old Jun 22, 2017 | 03:18 AM
W211Virgin's Avatar
2004 E320
-Nigel
will be looking forward to your response. ty
Old Jun 22, 2017 | 12:29 PM
cMazara's Avatar
w211 03'
I changed tails and no need to code, my car had factory leds, but the guy I purchased removed them to normal tails, then I bought led tails and installed them and everything is working fine with no code needed.
