E-Class (W211) 2003-2009
Xentry/DAS code re: low beam headlight
Old Jun 20, 2017 | 09:25 AM
Faridtaheri's Avatar
W211 CDI
My driver side bi-xenon is not working. Changed the bulb ($140!), yet still not working.
I ran the Xentry/DAS and got error code 9003 and 9007 (and a few others - please see teh screen capture below). They are as follows:
9003: component E1e2 (left low beam) is faulty or the lead has open circuit
9007: component E1e2 (left standing and parking lamp) is faulty or the lead has open circuit
Ironically, all other components noted by the Xentry (except the low beam) are functioning.
Any lead on what I should be looking for?
Cheers,
Farid
Attached Thumbnails Xentry/DAS code re: low beam headlight-20170619_202743.jpg
Old Jun 20, 2017 | 11:38 AM
W211 CDI
Thanks for the reply Plutoe.
Here is a dumb question (this is the first time I ma using my Xentry after five years of owning it)! How do I erase all the codes at once?! I have probably over 30 error codes, which I am confident are due to earlier issues, which should be erased.
Cheers,
Farid
Old Apr 20, 2026 | 03:17 PM
peru9800's Avatar
E350 Sedan (Base with Sport Package) 2008 (W211)
Cheers,
Farid
Hi, did you ever figure this out (9003: component E1E2 left low beam)... and do you remember (I know this is an old message)?
Old Apr 20, 2026 | 03:59 PM
timmy0tool's Avatar
2008 S211 4MATIC
i suspect the driver's side SAM was defective due to all the other faults related to that side of the car.
do some further research if you plan to replace yours as i'm not sure if there is any reprogramming needed.
Old Apr 21, 2026 | 10:48 AM
peru9800's Avatar
thanks. I'm curious if my front SAM is damaged or if clearing the codes or resetting things will do the trick.
