Daytime running light led module questions
it’s a 2007 e63 AMG and I was able to search thru here and find the part number 211-906-00-36
called the local Seattle dealer and they said it’s 112$ and 2-3 weeks out. Coming from Germany
is there a different option for these lights? Money is not the issue but it’s the time frame. I’m trying to put my light back together after removing the broken lenses, had to epoxy the cracked housing but the light didn’t work before removing the assembly, it said something about it on the dash and was full of corrosion.
also, because I removed it with the lense off, is it able to be replaced if I put it all back together, I read another post about someone having a hard time pulling it out or saying they can’t get to the screw or something?
any info is much appreciated
check wiring condition
Carefully observe what is missing ... solder joints.
Use a soldering iron to quickly fix this yourself.
the one that i got was just halogen which i new and understood i couldnt use some of the parts. the issue i am having is for the housing it does not have the little tab with the hole for the led module hold down screw. so i made a big mistake and tossed it thinking i could fix the chrome if you call it. yea chrome paint is not good. it did not work at all and i ruined the housing. so, i jumped on ebay, made what i think might be another mistake cuz the used headlight i bought for 75$ looks different. i have not recieved it yet. it shows up monday.
i will post some pictures, can anyone tell me if the high beam housing that is circled in blue has to little screws that hold the high beam bulb, is this going to look the same as the used one i just bought also circled in blue. i see the main difference so far is that mine has the round cap to cover the bulbs and this one i ordered has 5 screws that hold it in place.
im sorry if this is confusing i just was hoping to see behind that plate to see the back side of the chrome housing. i plan on cutting the tab off of mine and using epoxy to make it work for my led module.
ginal anywhere.
