Broken door Handle? (E-350)
Today,I noticed my driver side door handle was protruding out. I'm assuming some random person must of been yanking on the door handle thinking it was their car. Do I need to replace the door handle or can the handle be readjusted?
It appears that the handle is too far off to the left,so it's not closing correctly. The door still opens but it takes if couple of tries.
Received 1,467 Likes
There's a DIY on how to change the door handles if there's a keyless go problem. Taking the handle out shouldn't take more than 15-30 minutes, I think it's just one screw that holds things in. If it's not keyless go I think the handle is cheaper maybe under $100 if you get it online and depending on color or get one on eBay.
https://mbworld.org/forums/w211-amg/...ement-diy.html
Received 4,417 Likes
'71 Pinto
Remove handle, as suggested inspect assembly - may be repairable, see attachments.
a100steaksauce (06-24-2017)
how would you know if someone mistaken your car for their, were there more than one Mercedes where you were parked? Initially it looks like someone was trying to break in but I could been wrong, depends on where you were parked and what kind of area it was. Sorry to see someone did "accidentally" damaged your handle.
