E-Class (W211) 2003-2009
2003 E240 W211 - Noise Help
Old Jun 24, 2017 | 07:25 AM
newbie10's Avatar
e240 - w211
Hello everyone,
I own a 2003 E240 W211 and currently experiencing an issue which I am hoping that I could get some help on.
Every time I turn the ignition off there is a noise that seems to come from around the back of the radio / dashboard central speaker area which lasts for about a second. I have tried resetting the radio by taking off the radio fuse and the noise still occurs. I have also tried taking the 6 CD Changer fuse out and the central gateway and the noise is still there.
Link to the noise at the end of the video:
Any ideas on were the problem could be?
Any help would be much appreciated.
Many thanks
Old Jun 24, 2017 | 03:35 PM
konigstiger's Avatar
'71 Pinto
"May" be actuator motor. See attachments if you want to remove center air section to investigate.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 25, 2017 | 06:20 AM
newbie10's Avatar
e240 - w211
Thank you for your reply.
Would I have to remove the complete top part of the dashboard to get to it?
Old Jun 25, 2017 | 02:47 PM
'71 Pinto
According to WIS, yes. This is why I suggested removing center nozzle first to better identify noise. In addition to info previously posted, follow link and see attachments.
http://workshop-manuals.com/mercedes...ps/page_15859/
File Type: pdf
File Type: pdf
Old Jun 27, 2017 | 05:20 PM
newbie10's Avatar
e240 - w211
I will try on the weekend, thanks for your help on this.
Old Jun 27, 2017 | 05:34 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
konig is correct. Depending on which stepper motor dash may or may not need to be removed. You won't know which one though unless you actuate them individually or do a self test. There are alot of them in that dashboard, i would highly suggest you not guess at which one it is and pay diag time to precisely decipher which one is defective.
Old Jun 28, 2017 | 10:24 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
I believe our car actuates a servo (s) in the dash when the key is inserted as well, but there is no clicking sound associated with it. Just a gentle buzzing sound for a second or two. Sounds like yours has a clicking sound also that may be a blend door sticking or coming up against a mechanical stop?
Old Jun 28, 2017 | 04:58 PM
cmriv's Avatar
Correction. stepper motors move when CGW is woken up or when it goes to sleep.
Old Oct 24, 2020 | 03:18 PM
scrappy_doo's Avatar
Various
Sorry to dig up an old thread but have a slight cicking sound and STAR states:
9398 communication error of AC bus with component M2/8 (left defroster flap)
95B8 M2/12 Left center vent air flap actuator motor
95C0 M2/13 Right center vent air flap actuator motor
I've stripped the dash top off to examine but they appear to be working OK, also looking at the diagram of each motors location I cant see how I'd replace them.
Old Oct 24, 2020 | 05:05 PM
'71 Pinto
If you have not already done so reassemble 'check refrigerant' and clear codes before progressing.
Old Oct 24, 2020 | 07:09 PM
Various
Have cleared codes but they come back. 🙄
