E-Class (W211) 2003-2009
Battery dead, trunk does not open with key
Old Jun 26, 2017 | 06:41 AM
warlocky's Avatar
E200 2005 WDB211
Hi all,
First post on here and you are my last resort on this.
My car is left standing with no batteries, thus means I cannot open the trunk with the key fob and neither does my key work to the trunk, it simply wont open with the key.
The problem is that the battery is in the trunk so I cannot jump start it, as I cannot get to the trunk. What do I do?
I did find this (see attached image). Should I be able to attack jump starter cables (positive) to this and see if I get enough power to open the trunk? Perhaps, just a but. The jump starter cables are to thick and I cannot grasp the nut I highlighted on the image.
Kind regards,
A owner of a standing E200 2005, WDB211 that has no batteries and a defective trunk
Old Jun 26, 2017 | 06:58 AM
mtrevelino's Avatar
2006 E320 CDI
To open the trunk, did you lift the handle while the key is turned? The trunk will not open just by turning the key.
Mike T.
Old Jun 26, 2017 | 07:01 AM
warlocky's Avatar
E200 2005 WDB211
Mike T.
Yes, I have attempted this numerous of times but it simply wont pop open. Any other ideas?
Old Jun 26, 2017 | 07:22 AM
mtrevelino's Avatar
2006 E320 CDI
Sorry, no other suggestions from me. I would be careful connecting jumper cables to anything on our vehicles. Too many voltage spikes can happen. I still think opening the trunk with the key is your best bet. Try turning the key around (180 degrees). Another suggestion is to connect a battery through the cigarette lighter socket toi get power to open the trunk. You will have to turn the key on to open the circuit for the cigarette lighter. Here are a some of online searches:
http://www.mercedesmedic.com/how-to-...ercedes-trunk/
https://www.cargurus.com/Cars/Discussion-d74_ds474851
http://www.benzworld.org/forums/w202...pen-trunk.html
Good luck!
Mike T.
Old Jun 26, 2017 | 09:52 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Do you have fold down rear seats? If so, could you get into the trunk and try pressing the emergency trunk release from in there? I have no idea if that would work with a dead battery though.
Old Jun 27, 2017 | 05:32 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
user error. metal key always unlocks and opens trunk unless lock cylinder is defective.
and no, your battery is wired to your front pre-fuse, located beneath passenger front carpet, which in turn is wired to your passenger side sam. So you are in the incorrect location to jump battery. If you were trying to jump starter then yeah, driver side sam (purple wire). But battery is wired to front prefuse/pass-SAM.
Old Jun 27, 2017 | 06:26 PM
cetialpha5's Avatar
The simple question is does the key turn? If it turns, then you have the right key. Try turning it the other way. You lift the trunk handle while the key is turned. Worse case is you can try one of the cigarette lighter jump start packs. Takes a lot longer, but maybe you can put the key in, put power through the cigarette lighter and then hit the trunk open button.
Old Jun 28, 2017 | 10:18 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
This video shows how to work the steel key in the trunk:
Saw a video of a guy jacking the car up and attaching 12VDC power to the alternator to get the doors to open after the battery drained and he didn't have the valet key, but the keyless fob was operational.
Not a job for beginners or the faint at heart.
Old Jun 29, 2017 | 03:08 AM
warlocky's Avatar
E200 2005 WDB211
OK. I managed to get this fixed.
I spent countless of hours on google and yotuube, and finally after all attempts what only worked was this:
Thank you all for your help.
I'll add some keywords, as I suspect others will find this thread with time.
trunk wont open
w211 trunk wont open battery dead
trunk dead battery dead no key
trunk dead battery
e200 2005 w211
Old Jun 29, 2017 | 09:47 AM
cmriv's Avatar
I spent countless of hours on google and yotuube, and finally after all attempts what only worked was this: https://www.youtube.com/watch?v=E0YeSi0QywY
trunk wont open
trunk dead battery
e200 2005 w211
Old Jun 29, 2017 | 06:51 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
Hmmm. This is new to me, and I have been servicing 211's and 220's since they were first introduced! Thank You Warlocky. You learn something new everyday.
Old Jun 29, 2017 | 06:55 PM
ItalianJoe1's Avatar
2003 CL 600
You can jump them from the wiper cowl pre-fuse area, I've done it with a booster pack and a screwdriver to reach in and make the contact, gives you enough to electronically release the trunk and then apply the jumper on the battery.
Old Jun 30, 2017 | 06:10 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'd be working on finding out why the mechanical (key!) release isn't working...
Old Feb 28, 2019 | 02:12 PM
Bigslick78's Avatar
2005 E320
FIXED NVM
