E-Class (W211) 2003-2009
Trunk lid motor
Old Jul 18, 2017 | 09:19 AM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
I will give it a shot, but all is well, so I am thinking I shouldn't futz with it!
Old Jan 18, 2025 | 02:45 PM
AMGmann76's Avatar
96 c36/04 e55
Trunk lid question
Originally Posted by N_Jay
UPDATE:
Seems I have a new problem.
The power trunk feature does not work at all.
(Latch and Lock work as expected, from trunk handle, from door switch, and from remote)
Will not power open or power close. (No noise from motor at all, no motion at all)
Does the same thing from the handle, remote or drivers door switch.
The power latch cycles, so you can "pop" it and then hand open and hand close.
All rear taillights work fine. (Checked license plat light)
No dash error.
I think the red trunk buttons are not lit (Will check tomorrow). (Red Lights are NOT lit)
Guessing it is either a popped fuse, or maybe a different wire in the trunk bundle.
(Checked wire bundle and checked fuse. Both good)
I fixed the famous broken brown wire a coupe of years ago, and at that time none of the others looked bad, and I rewrapped the bundle to move the stress from that point.
(Fix looks good, unwrapped and no new signs of stress or rubbing)
Also wondering of it was a wire, why the remote or the drivers door switch would not work? (
Maybe a wire frayed and shorted taking out the fuse? (Nope and Nope)
Thoughts anyone? (HELP!)
All New Below
________________________________________
Kind of thinking it has to be the controller, the position sensor, or a secondary trunk open/closed switch.
Does anyone know if the trunk has a second switch that the controller may reed as a safety, or is the position sensor the only one?
Anyone have a controller or a position sensor fail?
Anyone have a diagnostic service sheet on the trunk opening system?
I thought the fuze was on drivers side quarter panel, what fuze should I check by the battery?
Old Jan 19, 2025 | 09:16 AM
N_Jay's Avatar
sorry, don't remember.
Old Mar 11, 2025 | 08:28 PM
Doingmybest's Avatar
E500 2005
Hello,
I've CAN issues. The trunk N111 module is suspect. Where is the N111 module located? Thank you all much.
Old Mar 12, 2025 | 05:36 PM
E500 2005
Originally Posted by Plutoe
I would look to the right side of tailgate--------or look here---Mercedes / Car > Mercedes EPC Online > nemigaparts.com
With your VIN I would love to know why you think you have a N111 module???
My scan rendered this N111 dtc specifically:
My trunk lid opens manually regardless of interior lock engaged.
And the below attached scan generally. Last year engine light turned on and fan at full speed. CAN issues galore. Scanner skipping over transmission. My attempts at a fix replaced front SAM, tested ECU, EIS with no effect. Replaced IC last week and new code litany rendered. Since the trunk lid has explicit problems, starting there seems reasonable.
File Type: pdf
Old Mar 13, 2025 | 07:13 AM
E500 2005
Plutoe,
It dawned on me that my ebay replacement IC must be from an e500 estate. Same IC model, programmed for a lift hatch. Got it now.
Time to turn elsewhere...
