Engine temperature overheating?
For the last couple of mornings, on kickdown (with rpm over 3k) the engine temperature goes well above 120C (in the IC). I switch off the AC before kickdown. It comes down though at 100C immediately when I take my foot off the throttle.
I would like to point out that my Engine Temperature would reach to 100 or 105C within 5-10 km of driving in the morning (outside temperature in early 30s in my area). So I am assuming that thermostat is working as it should. I can hear the auxiliary fan coming on too at that temperature (though it is quite loud), i can hear it with windows closed inside cabin at idle speed.
I have recently changed
- expansion water bottle since it was giving error message 'Check coolant level', after changing the bottle the message disappeared.
- flushed old coolant and put new MB 325.0 coolant (Green) (4.5 Litres) mixed with distilled water. My cooling system requires 11.6 litres as per my car's manual.
Any pointers are welcome.
I am relying on visually reading from the temperature guage. It may be 92C but from the temperature guage in instrument cluster I am reading it as 100C? Not sure. I think the thermostat is working because if I turn the heater on it works fine.
Thermostat - The fan kicks in as soon as the temperature reach 95-100C mark. If I turn on the heater hot air comes out of the vents. I have tried kickdown while heater is running and the temperature stays at 100 - 105C. (its 40C in my area)
Aux Fan - See above. If the car is on 100C mark and on idle after a couple of minutes, fan starts to slow down. I am presuming that this is working as it should.
Radiator - How can I check the radiator, obviously there are no leaks from it.
I see no obvious leaks on water pump either and the car is not running low on coolant either.
it can be a blockage but unlikely, i would try a new thermostat, sounds like its stuck closed (if you have a m272 its very common), when you have the rad hose off also remove the lower hose if you want to check for blockage and blow on it, should take no effort to blow the air trough the coolant
Could be bad thermostat, could be your radiator lost its efficiency, could be worn water pump.
When you have engine overheat, pull over and measure top of the engine, where the upper hose comes out, the other end entering the engine back and radiator in different points.
Point the thermometer to metal whenever you can and avoid pointing at rubber hose as this will change the reading.
I have a different guage than yours but my engine temperature stays exactly where yours is. i.e. ~100C. It goes to 120 on kick down though and it has been one of my worries. I want to nail it before I throw any money on parts on radiator, pump etc.
You can't expect radiator +- 10 years old to perform like new one.
Even MB coolant will develop some boiling stone over a decade.
The temperature went upto 100C on climate control screen which was consistent with the temperature guage on instrument cluster panel.
This morning while I try to run the diagnostics again the same value was reading as 40C whereas the Temperature guage in Instrument cluster was 100C.
Which sensor should I be looking to replace? Coolant or Engine Temperature Guage?
Secondly, Could it be the cause of car's overheating problem that I was having earlier? My understanding is that if sensor is reading 100C as 40C then thermostat valve is not opening up allowing the coolant to circulate?
Any help would be much appreciated.
Thanks in advance.
On older car coolant and engine temp sensor was the same thing, while thermostat was independent mechanical unit.
My 320 BT has computer-controlled electro-valve instead of thermostat and frankly I am not looking into troubleshooting the system.
If the sensor shows 40C on hot engine, it has to go, but again, where da heck is it?
Thanks to the forum members for pointing me in the right direction.
The wrong diagnosis by my mechanic cost me a radiator and crankshaft sensor which had gone bad after overheating.
Glad you got it though! The thermostat was the first thing I had to change on my CDI because the engine wouldn't heat all the way to proper operating temperature. As has been said: Common problem.
