M272 timing chain stretch test?
Hi,
I have the engine out of my car for the balance shaft gear issue and I thought I should check the chain for stretch. I haven't got the engine apart enough yet to see if there is significant wear on the chain but I was thinking that if there is negligible wear and stretch I wont bother replacing it (110,000 km on the clock).
I have access to WIS/ASRA but cannot find a procedure for determining chain stretch. Anyone able to advise?
Thanks, I'm assuming you're referring to the valve timing method. The only issue I have with that is that there are no clear values where a chain replacement is recommended, or did I miss that?
2012 Cls63 amg
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1124/20191102_143022_df6150cb5685dc34b2e8966098ff19479dd7801b.jpg)
With all parts removed as mentioned above to gain access to these lines which got to driver side tutbo
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1124/20191102_143048_70f4c9b82a9345be1971c2ea2c40d6690f5b9f48.jpg)
Line to driver side turbo. I replaced both lines to that turbo as they were brittle to touch. Caution as male part with o-ring may break off inside block. Not to worry what i found to work for me since i had it was piece of wire hanger with one side bent like an L and the L part of the hanger inside the broken piece in block and carefully pry towards the radiator and a lil wd40 to lube oring and popped right out. NOTICE THE ONE MOUNTING HOLE FOR EACH LINES. Others may have 2 holes to mount.
