Lot of electronic failures?
Over the last few weeks I've been getting a random "esp inoperative" warning. It doesn't come on every time I drive the car and it's usually off after restart.
Last night, I got a "right side low beam out". Car has an aftermarket hid kit that's been installed for about a year or so. I replaced the ballast with a spare this morning and it worked.
Took a 300 mile trip today. After about 150 miles the esp inop message popped up. Didn't think much of it. Drove another hour and got a warning that the right side low beam was out again. Shortly after I stopped for gas and upon restarting car, I got all kinds of errors. Esp, abs, srs, speedtronic, etc.
I turned the car off and went inside the store at the gas station. When I got back in the car, it wouldn't start. Nothing happened when turning key. No crank etc. after 5-10 mins it did start. I headed back on the road, and noticed it wasn't shifting right. From a stop it was revving a lot to get going. All the warning lights were still on, the speedometer needle was bouncing around and the nav was (and still) stuck about 50 miles back from where I am now. Once on the highway it ran fine.
I was able to get my bt obd2 scanner and torque working at one point but it no longer does. It showed 14 codes at that time but I wasn't able to jot them down.
At this point, the car is home. It starts every time but all the same warnings flash and as soon as it starts, the cooling fan is on full blast and won't go off. At one point I also got a red battery icon. The battery is about 6 months old. It's an AGM from advanced auto. I've since put it on a charger and fully charged it and all the same issues persist.
I thought this was an alternator or voltage regulator but since it's charged now and having the same problem I'm not sure. Maybe an ecu issue but hoping someone has some ideas on how to proceed before towing to dealer.
Thanks!
I searched for the battery control module from a parts standpoint and didn't find anything for w211s past 2006. Did they do away with it when they dropped the 2nd battery?
Turn all the headlights, rear defroster and blower and then read the battery.
13.3 climbing to 13.8V alternator voltage indicate some problems as well. How old are alternator brushes?
Only three errors are currently displayed. "Pre safe inoperative", "SRS malfunction", and "speedtronic malfunction". Aside from that, the cooling fan is still on full blast, there appears to be no or very little power steering, and the gear indicator lights on cluster are not showing. The comfort/sport indicator is also blank right now. It appears to be shifting through all the gears and drivable enough to get it to a shop or dealer right now.
I knew this going into the purchase
Best place to start is make sure the electrical charging system has the capacity to run all those electronics. This includes using the correct size "AGM only" batteries that the vehicle was designed to run and making sure the alternator's voltage regulator is functioning correctly. I replaced all of these items and many electrical gremlins went away.
Dude -- if you're bringing it to the dealer for service, the car will become rapidly unaffordable.
When you have multiple possibilities, you always start with simplest and cheapest issue.
$60 for Voltage regulator and 1-2 hr of DIY is sure cheap and easy enough.
But when you take it to stealers, it will make about $1600 for alternator replacement and open whole chain of events.
