E-Class (W211) 2003-2009
Misfire under load
Old Sep 13, 2017 | 02:05 PM
Raj Morar's Avatar
2002 mercedes e320 w211 petrol
Misfire under load
Hi Everybody. Please help. I recently purchased a second hand engine for my car (E320 petrol). The engine arrived with a spark plug attached to the plug lead, like the previous owner was checking for spark. I fitted the motor which started up perfectly. It drive smooth under normal driving. The moment you apply load, like up hill, its picks up a severe misfire. No codes and on real time data, it does not pick up any cylinder misfire.
I changed, the plugs, coils, injectors, injector rail, egr, throttle body, air flow sensor and all pneumatics. In fact I changed every part and item above the engine. According to diagnostics, this car is perfect. Why is it misfiring. Please I will appreciate any assistance.
Old Sep 19, 2017 | 11:11 AM
Raj Morar's Avatar
UPDATE: I just returned from the engineer. Pressure tested both heads. No leaks or cracks. No problems with the valves.
Old Sep 20, 2017 | 01:06 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
but did ya change the coil sparkplug WIRES?
Old Sep 21, 2017 | 02:17 AM
Raj Morar's Avatar
Sorry. Should have mentioned it. I did change the spark plug wires.
