E-Class (W211) 2003-2009
4-Matic Transfer Case Drain Plugs Frozen
Old Sep 14, 2017 | 06:45 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Was changing the 4-Matic transfer case fluid in our '04 E500 but only got so far before I found the filler (inspection) and drain plug frozen in place. I would have thought the cross-member would have given me the most problem with it's rusted bolts. That went like butter.
This issue is common when steel plugs are installed in aluminum or magnesium casings with no anti-seize on the threads. I've been soaking the plugs with Kroil brand penetrant to hopefully free them up.
I've got the right fluid I hope and will probably use the "inspection" hole fill. I have read contrasting fill procedures. One that case should be filled slightly above the inspection port and one that says until it just drains out. I'll probably just fill it up until it wants to pour out and force a little more in there and quickly install the plug.
The other lingering web discussions are to use fluid MB 001989230310 or 311. All I could find is the 310. I read that the 311 is a discontinued 5 liter
After filling, should I do some figure 8's to disperse the new fluid through out the casing? I would assume you would want the new fluid to saturate the internal clutches.
Old Sep 15, 2017 | 09:20 PM
Got the plugs out with the magic Kroil. The case was filled a bit above the inspection hole previously. I was able to get a bit extra in the inspection hole with the HF transfer pump hose. Pumped in 650ml and sealed it up
https://www.harborfreight.com/multi-...ump-63144.html
