E-Class (W211) 2003-2009
2000 ml320 shop added wrong fluid in transmission
Old Oct 9, 2017 | 01:30 PM
keepselling's Avatar
2000 E320
Had a transmission flush. They added half correct fluid and the other half of the fluid was red transmission fluid. Wrong fluid. Several months since the service and the transmission won't shift out of first gear. Can this be corrected with a correct fluid flush. I am going to look at the ML320 and pull codes to see if there are any. I know there will be codes. Not my car
Old Oct 9, 2017 | 04:07 PM
Russell Ormerod's Avatar
not a merc
Doubt the oil is the issue
Old Oct 10, 2017 | 06:44 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
So this person knew the wrong fluid was put in and then still drove it for months?
Old Oct 10, 2017 | 07:39 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
That symptom you describe does not sound like a fluid type issue. maybe conductor plate. Have it scanned with a proper SDS computer and it might point you in the right direction. Good Luck and please keep us posted on what the repair was. Cheers..
