E-Class (W211) 2003-2009
2007 e350 merc wagon
Old Oct 9, 2017 | 06:59 PM
nuchana's Avatar
e350 wagon
200,000 miles on the car
have added three quarts in last 1200 miles
no leaks under car or from exhaust
any ideas?
Old Oct 10, 2017 | 06:42 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Have you done a compression test?
Old Oct 10, 2017 | 07:30 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Did you actually remove the belly panels to check for a leak or are you just looking on the ground?
What prompted you to add oil? Is it just the sensor on the dash that's telling you to? Have you verified the oil level with a dipstick or by draining?
Old Oct 23, 2017 | 12:23 PM
nuchana's Avatar
e350 wagon
I believe I had my numbers above wrong.
Seems like 1 quart per 1000 miles is when I've added.
And, was told when I have my next oil change they will install new oil filter that will help. Last change was about 10,000 miles ago.
Thank you!
Old Oct 23, 2017 | 12:24 PM
nuchana's Avatar
e350 wagon
1
Old Oct 23, 2017 | 02:34 PM
nuchana's Avatar
e350 wagon
have not done a compression test
Old Oct 23, 2017 | 02:36 PM
nuchana's Avatar
e350 wagon
did not remove panels
sensor telling me, and when i check dipstick it confirms need oil
Old Oct 24, 2017 | 09:37 AM
2013 ML350 Bluetec
1 quart in 1,000 miles is what some mechanics would say is acceptable consumption.
I wouldn't, but some would.
If there's a leak, the belly panels should catch it. Compression test is a good call too.
Old Oct 25, 2017 | 08:52 AM
nuchana's Avatar
e350 wagon
Thank you!
I will take her in for service b next month.
Cheers...
