E-Class (W211) 2003-2009
Throttle/rev problem after 5 min driving
Old Oct 30, 2017 | 10:49 AM
Matulevicius's Avatar
Mercedes W211, E270 CDI
Hello all. I am new to the forums and quite new to cars.
CAR: W211, 2003 E270 CDI, 270000km
What was done recently: the car had egr valve cleaned, intake manifold flaps engine replaced (small part, used, for about 40eur) - engine to move the flaps i mean.
Before the repairs the car had completely no power, 1st gear revs to 2.5k and thats it. Other gears lower than that and throttle response is poor.
no check engine light.
My recent symptoms: start the car up, drive 5-6 minutes and 70% or the time, after those 5-6 minutes, the car jerks a little bit (as if you would be out of fuel), and then any throttle pedal movement basically gives an extremely small amount of power and same symptoms as before.
The service tech expects intake manifold flaps problem - replace the whole manifold
the service tech now disconnected the egr valve as well as they were getting both air amount code and the egr valve code.
And now the car has full power all the time but check engine light is on, of course.
Anyone had similar symptoms?
Could rhis be simply a bad egr?
Old Oct 30, 2017 | 10:52 PM
cMazara's Avatar
w211 03'
Many people damage electrical parts while cleaning, maybe he damaged the valve sensor..
Old Oct 31, 2017 | 01:57 AM
Originally Posted by Plutoe
Sounds as if you have found your problem, however read up on the function of the EGR on a CDI engine
Dear Plutoe,
Thank you. So you too agree that this is an egr and not a intake manifold problem?
Didnt think about that one. Thanks, will check with the service tech!
Old Nov 1, 2017 | 01:43 AM
Anyone else have any thoughts?
Old Nov 1, 2017 | 05:37 AM
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
CDI control unit is putting car into a pseudo limp mode that governs engine's RPM to not exceed 3K though doesn't always trigger CEL so real-time OBDII data should be monitored to reveal which codes come up during operation. I suspect positioning motor of swirl flaps is intermittently binding but could be VNT (variable-nozzle turbo) related also or air intake sensor or EGR damage. Understand this car is heavily dependent on computerized components to run so need a computer that can talk to it for proper diagnosis. A bootleg SDS system off Alibaba will pay for itself with 1st use as it eliminates diagnostic fee dealer of mechanic will charge to use theirs.
