E-Class (W211) 2003-2009
La Power Bluetooth A2DP USB adapter
Old Jun 8, 2020 | 03:07 PM
  #126
DerPicknicker's Avatar
W
Try a firmware Update... It could fix this issue.. I can’t provide any changelogs.. Sorry for that. Try pressing the Button „8“... I read something about the „T“ -Button. I will send you tomorrow my manual of the Lapower.
Old Jun 8, 2020 | 03:20 PM
  #127
nguyenphananh's Avatar
slk280
Thanks, will try all your technique when I get home today.
Old Jun 8, 2020 | 05:02 PM
  #128
slk280
I just "studied" the update process that included in your pdf, and I noticed, according to the pictures, there is a SD CARD SLOT behind the device, next to the fiber optic connector!?. My device DOESNT HAVE this SD card slot!!?? I plugged the update card into the slot at the front, maybe thats why it didnt update?! can you confirm this information?? Maybe my device was the early generation, and didnt have this slot?! The paper that came with the device (when I bought it), said "LaPower 1600 serie"........
Old Jun 8, 2020 | 05:05 PM
  #129
W
I could imagine that this is why your LAPOWER won’t update. Where did you buy it? And how old is your Module.. ?
Old Jun 8, 2020 | 05:10 PM
  #130
slk280
I bought my on amazon, at the end of 2018..... so it shouldnt too old. Its worked fine except listing the wrong song names, and difficult (dont know how) to switch sources.!!!
Old Jun 8, 2020 | 05:22 PM
  #131
W
Okay.. I would suggest to contact the seller or contact mr12volt.com ... They have an Contact-Area.
I can’t provide more information.
@Pmarino In the next days I could say more about Siri ..
Old Jun 8, 2020 | 05:51 PM
  #132
slk280
do you have the link where you buy your device?? thanks
Old Jun 8, 2020 | 05:57 PM
  #133
W
My Product is not in stock .. check it later again.
I bought it from this seller : https://www.ebay.de/usr/lapowerstore
Old Jun 8, 2020 | 06:13 PM
  #134
slk280
Thanks, I will contact the your selle, asking if he know, or has any solution for your earlier generation of device
Old Jun 8, 2020 | 11:38 PM
  #135
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
User Manual
https://drive.google.com/file/d/1PMNJcgB2D5ITJOwwZr-HhMY-sYSXvuGT/view?usp=sharing
Old Jun 9, 2020 | 12:59 PM
  #136
slk280
Thank you. The user manual came with the device looks similar to that, except it doesnt have the section show how to change sources. Also press #6 doesnt work for me. I figured out press and hold Mute, Unmute for 1 second will switch sources!!
Old Jun 9, 2020 | 02:46 PM
  #137
Pmarino's Avatar
I just lost blue tooth on the C320 Aux plug still worksI emailed support.....i'll update when info becomes available.
Old Jun 9, 2020 | 03:11 PM
  #138
W
Try unplug your command power and the la power... try reset the lapower...
Old Jun 9, 2020 | 03:38 PM
  #139
CastorTroy's Avatar
2014 E550
man, reading through this thread makes me happy i replaced my headunit with a kit from enfig
Old Jun 9, 2020 | 03:53 PM
  #140
Pmarino's Avatar
Yea i did the plug unplud, reset dance.....Probably needs to be replaced. I'll try the unit from my ML, that I know is working 100%.
Old Jun 9, 2020 | 03:54 PM
  #141
W
I would say this is not a good deal... No 3rd Party Radio has this brilliant sound and clean look.
And also no 3rd party radio has this brilliant radio tuner.
  #142
Pmarino's Avatar
That's nice.....
Old Jun 9, 2020 | 03:55 PM
  #143
W
Try a firmware update if your module has this sd slot
Old Jun 9, 2020 | 04:01 PM
  #144
Pmarino's Avatar
It was working fine, then got a little flaky connecting (according to my son) now the blue light won't come on, only the red. I think it's the BT transmitter. If all else fails I'll try the update and open it up and check the board.
Old Jun 9, 2020 | 04:09 PM
  #145
W
if you open the board...
PLEASE make Good pictures from the Board an all components and please also from the backside of the Board.
Old Jun 9, 2020 | 04:11 PM
  #146
Pmarino's Avatar
Old Jun 11, 2020 | 05:21 AM
  #147
W
Hello,
did anyone get a message from the seller? I will write again I hope that eBay improved their Message System.
Old Jun 17, 2020 | 12:43 PM
  #148
W
Any updates?
Old Jun 17, 2020 | 01:00 PM
  #149
Pmarino's Avatar
Nope, I went through the web site. I'm goning to try the seller.
Old Jun 23, 2020 | 05:17 AM
  #150
W
Any Updates? Did you open the Devices?
