E-Class (W211) 2003-2009
Timing chain replacement
Old Nov 28, 2017 | 08:55 PM
NVR ENUF's Avatar
2008 E350
When should the timing chain be replaced? My mechanic told me it should be around 150k miles.
Old Nov 28, 2017 | 09:57 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Find a new mechanic. It’s not a scheduled maintenance item. You’ll get timing error codes if the rails are excessively worn or the chain is stretched.
Old Dec 24, 2017 | 09:01 AM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
I asked the same question at an independent MB Repair Shop..........manager said the timing chains are designed to last the life of the engine and, as you indicate, you'll get an error code if it's worn and needs replacement.
Old Dec 24, 2017 | 11:06 AM
angelglo's Avatar
Veteran: Marine Corps
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
What he said! that is an expensive repair and he was gonna take your $ for no reason but to pad his wallet. If he is dishonest about that, I'm sure there are other things that he has told you that was not true.
Old Dec 26, 2017 | 10:50 PM
NVR ENUF's Avatar
2008 E350
Yep, its a $1500 job. I asked another mechanic and he said its always good to change out at about 150k-200k. I will take your guy's advice and wait for an error code. Has anybody here ever had to change a timing chain? Sounds like it hasn't been done. I have a Land Cruiser with nearly 250k miles and was told the timing chain never needs to be replaced but then I hear mechanics say they do go bad over time
Old Dec 29, 2017 | 11:53 AM
kjb55's Avatar
I know of no manufacturer that lists timing chain as a maintenance item - preventative or otherwise. It's a wear item - but think of it like an alternator. It's a wear item too - but you change it when it fails. Timing chains stretch and the guides wear (ie: go bad over time) - but the tensioner is there to keep everything in time. The biggest factor is that they typically don't break - as in snap a link. That's what makes a timing belt require a defined change interval.
Old Dec 29, 2017 | 12:37 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Alternator brushes ARE wearable. They last long time (even 250k miles if you don't use lights a lot) but they WILL wear.
Than MB makes their maintenance books up to 150k miles. What happen after that, it is up to the owners.
Old Mar 10, 2022 | 08:25 AM
TuroAMG's Avatar
2018 S560, 2018 GLE43, 2021 C63S
Timing Chain Replacement
My 2012 ML350 threw me some timing codes related to the camshaft along with a longer cranking on the startup. (130k miles)
after replacing the camshaft magnet and sensor the car was still throwing codes as well as cranking longer
Now my ML is at the Mercedes service center, they told me they’ll need to open up the head valve cover, check camshaft, and replace the stretched timing chain
All in all I estimated it will cost me between $2-3k
Note: The car has some performance modifications and I am young and horse it around all day. Despite this, I love the car and never plan on getting rid of it. After all it is the first rather expensive problem ive had with it after 130k miles
2012 ML350 Bluetec 4matic 3.5L V6
Old Mar 10, 2022 | 10:31 AM
tjts1's Avatar
C320
wow that's really cheap!
