E-Class (W211) 2003-2009
Black spots on the dashboard
Old Dec 10, 2017 | 05:01 AM
albania's Avatar
e220 cdi 2005
hello
today I saw some dots or spots on the dashboard
do you have an idea what is happening???
can I clean them somehow ??
thanks
Old Dec 10, 2017 | 09:38 AM
konigstiger's Avatar
'71 Pinto
IC can be disassembled in an attempt to clean just be attentive/careful of ribbon cable/connections see here: https://mbworld.org/forums/clk-class...ml#post5465249
File Type: pdf
Old Dec 11, 2017 | 05:14 AM
albania's Avatar
e220 cdi 2005
I dont understand what happened with it ?!?!?
it just appeared one day :O
Old Dec 11, 2017 | 10:19 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
did the car have moisture or water inside the interior at some point? Possible mold issue?? I've been around many of these cars for years and I've never seen spots like that inside the gauges.
Old Dec 11, 2017 | 01:24 PM
albania's Avatar
e220 cdi 2005
in fact I have tried to clean the ac system with spry foam cleaner maybe 2 weeks ago
I have sprayed it on the air vents
this f...... cleaner should be
Old Feb 27, 2018 | 02:53 PM
farleykarley's Avatar
W108,R129,W211
Did you fix it in any way?
Got the same problem with my 211 now. And my wife's parents. Their 211 has gone over 460.000km so i tought it had something to do with the high milage and long running time, but mine has only half of the km´s and now has 2 black spots aswell..
Really disturbing, and I'm not in the mode to change the whole instrument cluster.
Old Feb 27, 2018 | 09:17 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
hello
thanks
Girl- "What's t'he matter billy?"
Billy- My doctor says I have Skittles pops
Girl,- " Is it contagious"?
They kiss
Billy,- "I don't think so "!
It's only humor, we all have some problems
with our w211 so we're in the same boat!
2MERKS
Old Dec 24, 2019 | 07:06 AM
albania's Avatar
e220 cdi 2005
now it is something else
last night I saw a strange yellow light like a tiny glowing spark moving around the cluster, sometimes on the bottom part sometimes on the other positions, it was very strange, seems like a short circuit of leds or something similar, do you know something similar ?
Old Dec 27, 2019 | 03:20 AM
albania's Avatar
e220 cdi 2005
with the time passing it is getting worse, black dots all over
one service guy said it has the panel damaged and should be changed, others say it can be repaired
did anyone opened it to clean?
or all of us should exchange it with a new one?
Old Feb 2, 2021 | 01:22 PM
freddesson's Avatar
Mercedes Benz W211
did you find a solution? got the same problem with mine
got black spots everywhere now, cant barely see the watch anymore
Old Feb 11, 2021 | 11:25 AM
Erudito's Avatar
E220 CDI W211
In case somebody in the future finds this thread - problem is the white paper (it is actually "light" paper, dont know how to call in english). There is no led lights behind speedometer/clock etc, its the white paper itself that transmits light. It may burn down over time. Only solution is to dismantle the IC and replace the white gauges by new ones, which you can cut yourself, only problem is to find the paper itself. Then you solder 2 wires to it, connect them to IC and all done, new and bright again.
Old Nov 15, 2021 | 05:26 AM
kevi's Avatar
mercedes e270 w211
i have the same problem with my w211. I disassembled the instrument cluster and tried to clean it but it didn’t appear to have any difference. Im thinking of swaping the entire instrument cluster to a new one but im not sure if it needs any coding after??
Old Nov 15, 2021 | 09:24 AM
'71 Pinto
You will need MB diagnostics to transfer stored data from original to replacement for simple swap see here: https://mbworld.org/forums/e-class-w...ml#post7332126 view attachment & follow link to circumvent coding. Post VIN if you want me to pull instrument cluster part #.
Old Nov 19, 2021 | 04:04 AM
MariusNL's Avatar
Mercedes w211 2007
I also have the same problem. I was searching and found this site where you can order the gauges: https://www.heiler-tachodesign.de/Ga...260-Kmh-Diesel
But I don't whether the colour of light of these gauges are the same as the original ones. I want exactly the same colour, not that cold LED-like blue-ish white, because that wouldn't match the rest of the interior. Everybody could see that it's not original.
