Bolt/Nut Tightening Torque Specs Please!
Axle Bolt 27mm
1. Knuckle Nut 2. Control Arm Nut
Questions:
1. Torque Spec for Lower Ball Joint. There's 2 nuts (22mm) . Are they both the same spec and what is it?
2. Torque Spec for Axle Bolt (27mm)
2008 E350 4Matic
Found this on Pelican Parts, 90nm Axle, 55nm ball joint (both nuts?)
Different years 4matic and the axle and joint specs are totally different.
Axle Collar Bolt = 2 stages, 70 nm + 90°
Is this the correct torque for 2008 E350 4Matic? Its says for Model 211.08.
From AutoZone repair guide for 2000-2005 Mercedes
100nm for 1 nut, 140nm for the other nut.
Thanks for the help!
2008 E350 4matic
