E-Class (W211) 2003-2009
Standard tank size on E220 CDi?
Old May 10, 2004 | 07:50 PM
russellfray's Avatar
I've searched and looked and can't find anywhere that tells me the standard fuel tank size on a UK spec E220 CDi. I know the bigger engine models come with an 80 litre tank, and you can get the 80 litre tank as an option for £80 on the smaller engines. But.. what's the standard tank size?
If the standard is 65 litres or less it's probably worth spending the £80 on a larger tank so i have to fill up less often. But if the standard tank is 70 or 75 litres it's not really worth it.
Also - with the larger tank, do you lose any space in the boot/trunk?
Thanks,
Russ.
Old May 10, 2004 | 08:04 PM
Apollo's Avatar
E320 CDI Elegance auto
Think its 60. No loss of boot space with bigger tank. Would go for it, small cost. Only lose a little boot space if you have airmatic.
Old May 10, 2004 | 08:42 PM
Thanks - will definitely go for it
Old May 10, 2004 | 10:29 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Standard tank size on E220 CDi?
Thanks,
Russ.
Presuming you mean the saloon... the size is posted on the mercedes-benz.co.uk site... 65 litres.
-s-
