E-Class (W211) 2003-2009
how do i stop one of spark plugs from soaking oil
Old Jan 10, 2018 | 09:35 AM
airjaron's Avatar
2009 E350
my car is a 2009 E350 mercedez benz
Old Jan 10, 2018 | 02:04 PM
Russell Ormerod's Avatar
not a merc
Soaking with oil! Determine if its coming from valve or bottom end! Then strip it to repair
Old Jan 10, 2018 | 02:51 PM
LexBrett2's Avatar
2007 Mercedes E550
Your spark plug gasket has likely failed. These are the gaskets that you also change when you do your valve cover, and they usually come in a kit. It is a DIY job but lots of time, save a bunch of $$$ though
Old Jan 10, 2018 | 10:38 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
yes, I second that, it's the spark plug tube gasket has failed and when you're replacing it, it's gonna come with a new valve cover gasket as well.
Old Jan 11, 2018 | 09:10 AM
LexBrett2's Avatar
2007 Mercedes E550
Originally Posted by Plutoe
Change the spark plug, wire and coil for that cylinder
It is probably the gasket that is leaking!
