E-Class (W211) 2003-2009
error message at start
Old Jan 23, 2018 | 04:34 AM
garygt40's Avatar
1999 E320
W211 2009 E350 speedmatic and cruise control inoperative when the car is started. Turned it off and the error went away.
Old Jan 23, 2018 | 11:35 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Steering angle sensor.
Old Jan 23, 2018 | 01:39 PM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
https://mbworld.org/forums/w211-amg/...ensor-sas.html
Old Jan 24, 2018 | 06:30 PM
garygt40's Avatar
1999 E320
I am off to the dealer to purchase the part. I reviewed YouTube on how to replace it, doesn't look that difficult. Thanks everyone for their replies.
Old Jan 25, 2018 | 02:41 AM
cetialpha5's Avatar
You can just buy it online. Cheaper than the dealer.
https://www.oediscountparts.com/part...&siteid=215242
Did mine a while ago, only tricky part was probably the nut for the center steering column, had to use an impact gun to get it loose. Otherwise the youtube video is pretty much spot on.
You might also want to get the car scanned to make sure it's the steering angle sensor, a bad wheel sensor or some other part could also give you the same error. I had an OBDII scanner that gave me specific MB codes and it gave me the bad steering angle sensor code.
Old Jan 25, 2018 | 03:07 AM
garygt40's Avatar
1999 E320
Great advice I will get it scanned before diving into it.
Old Jan 25, 2018 | 03:12 AM
cetialpha5's Avatar
I hope you know someone or can buy a cheap one, they range from $50-$100 or more. The dealer probably charges $150 just to have it scanned. The ones at the auto parts stores won't pick it up, they just do standard OBDII codes which is basically engine and emissions.
