E-Class (W211) 2003-2009
Electric trunk opener issues
Old Jan 27, 2018 | 09:37 AM
relinuca's Avatar
2009 E350 4Matic Sport sedan
Our beloved '09 E350 has a problem with the "electronic trunk closer" system. Any forum advice will be appreciated.
Here's the problem: when opening the trunk by either using the interior switch (driver's door), key fob, or exterior trunk latch, the trunk only opens about 1/3 of the way, and then stops thereby requiring you to manually open it the rest of the way. Once partially or fully raised, it will not electronically close...you must manually close it.
???...is this some kind of "synchronization" problem?
relinuca
Old Jan 27, 2018 | 02:32 PM
cetialpha5's Avatar
Did you read the thread about the wiring in the trunk? Sounds like you don't have power to the trunk closer anymore.
Old Jan 27, 2018 | 10:11 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Perform an advanced search in the W211 and W211 AMG sections using the user name "Konigstiger" and key word "trunk". He posted a reply with several attachments on this within the last two months.
Old Feb 26, 2018 | 07:38 AM
relinuca's Avatar
Electric Trunk Opener issues
The problem was damage to the wiring loom...near the hinge. The damage was apparently caused by the opening/closing activity (flexing) over time. The Tech spliced out the damaged area and spliced in a new section...problem solved. (I am surprised M-B didn't shield the wiring loom at that location.)
relinuca
Old Feb 26, 2018 | 01:00 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is the exact issue and fix, I had with me 07 E63 last year. As these cars age, the wiring get brittle after years of flexing and bending.
Old Sep 18, 2020 | 02:30 AM
defalt's Avatar
2005 S 350 L W221 (1637th produced), 1981 300 GD and 1985 280 SEL in restoration
Hi! Thanks for sharing this. Would you mind telling us the process of how you did it ? I would love it on my W219.
Old Sep 18, 2020 | 02:29 PM
konigstiger's Avatar
'71 Pinto
