W211 right tire size
1922 Ford Model T / no OBD
How wide the rims?
Each rim allows for about 20 mm different tire width, so if you want to play with different sizes, start with checking rpm of orginal tires and then once you find favorite tire model - chose the size that gets close to original rpm.
245 are wide tires for E and if you care more about fuel economy than hard cornering, - you can go narrower than that.
If the looks are your only priority- go for 300 in the rear and I thing 285 in front will fit.
The rims
How wide the rims?
There is no such thing as standard wheel on car model.
Did not see the catalog for W211, but W210 was living factory with more than 50 different wheels options.
Obviously the number doesn't make it to America.
they have a w211 part number ill post it when i get them back
the tires they came with were 215/50/R17 front and 245/45/R17 rear
Looks like good rim, but that model never made it to America.
US/Canadian models come heavy loaded, so are heavier than most other country models, what also adds wider wheels.
http://www.auto-brochures.com/makes/...Class_2005.pdf
