E-Class (W211) 2003-2009
FUSE FOR LEFT SIDE FRONT LIGHTS?
Old Feb 11, 2018 | 12:53 PM
merchauser's Avatar
e350
My left side front turn signal, left side marker, and left H7 high
beam are all out. is there a fuse for the left side lightening?
Old Jun 8, 2018 | 05:58 PM
merchauser's Avatar
e350
update: my left side marker had water in the housing. cleaned it up, new bulb and that works fine
opened up the LH headlight assy and found many bare and shorted wires. rewired what I could, and now
I have restored my H7 high beams. also, my turn signal now works, but NOT on the left side of the car.(I plugged
it in on the right side, and it works there)
SO, posing a new question. as mentioned, I was able to restore the function of the turn signal within the
headlight assy, but something in the chassis wiring is prohibiting the turn signals to work, on the left side.
within the fuse boxes are "pre fuses" and I am thinking that I might have toasted one of those. is there a pre fuse
or fuse dedicated to the front left turn signal that I might need to repair, AND is this in the fuse box in the trunk,
or the one on the drivers side under the hood.
Old Jun 8, 2018 | 06:12 PM
merchauser's Avatar
e350
post your VIN or send Konigstar a PM requesting the info!!
plutoe, what is Konigstar? my VIN is WDBUF56X6 7B128113
Old Jun 8, 2018 | 06:17 PM
konigstiger's Avatar
'71 Pinto
Left turn signal = E1e5 wired direct into front SAM N10/1 (engine compartment) also ground W9 @ left headlamp see attachment.
File Type: pdf
Old Jun 8, 2018 | 07:09 PM
merchauser's Avatar
e350
thank you very much for reply.
would you like to speculate why I might have signal no LF turn signal? all other signals function properly.
I thought the pre fuse for 10/1 SAM was in the trunk? you are saying it is under the engine bay fuse box?
what other functions does 10/1 perform? first I lost my LH main beam and now I have lost RH; any correlation?
Old Jun 8, 2018 | 07:34 PM
merchauser's Avatar
e350
ok, I found out the 10/1 pre fuse is located in the fuse box found in the trunk, just forward of the battery
hoping that might be my issue, but wondering if that pre fuse controls other functions that I can test?
Old Jun 9, 2018 | 08:03 AM
merchauser's Avatar
e350
just did another test, and was surprised to find out that the connector that plugs in behind the H7 high beam,
controls the turn signal as well. thought that the turn signal function was related to the plug for the main beam.
Old Jun 9, 2018 | 11:09 AM
'71 Pinto
Check connections @ front SAM if they seem fine could be harness. Also see details in attached bulletin.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 1, 2018 | 11:35 AM
merchauser's Avatar
e350
calling Konigstiger!! have resolved many issues by rewiring the internals on the LH headlight assembly.
however, I am not getting any voltage at the grey/black wire for the LH front turn signal. in the wiring diagram
you sent me, (below) that wire, 48a, shows a rectangular box near the top. is that a fuse or a fuse link?
Old Jul 8, 2018 | 10:09 AM
merchauser's Avatar
e350
UPDATE: the plug at the headlight is NOT the issue. there is continuity from the turn signal plug all
the way up to the front of the fuse box on LH side of engine.
so....my issue is under the fuses and perhaps that will give someone more insight in pointing me in
a direction??
Old Jul 17, 2018 | 11:47 AM
'71 Pinto
Driver-side SAM actuates the left turn signal lamp (E1e5). Check connector M3, pin 5 (M3/5).
File Type: pdf
File Type: pdf
Old Jul 22, 2018 | 12:55 PM
merchauser's Avatar
e350
back at it: the left turn signal wire travels from the bulb assembly, thru the harness to connector M3, which plugs
into the bottom of the LH under hood fuse box/SAM.
at check for continuity, from the bulb to connection 5 on M3 and it is good. I also fed 12v to pin 5 on the M3 connector
and it powered up the lamp
I have attempted to establish continuity from pin 5 on the underside of the fuse box, and cannot follow the path. cannot
find the point of continuity??
I read a post about the turn signals having an electronic fuse? surely that would not be separate for each flashing bulb
how do I trace back from pin 5 and discover when my disconnect is?
