Easiest way to hardwire Dash Cam?
I am trying to hardwire a dash cam to my W211 E550. I found a video on Youtube showing someone wiring it to the ODB port. But when I tried to do it on my car, it looks different than his (mines don't have the side panel that can pop out. It is just a vent).
On my other car I just tapped to the rear view mirror for power and ground.
Any suggestions?
I found the best spot for camera next to rear-view mirror and having 3 units that need power, I runs small cable from cigarette lighter socket into glove compartment, where multi-socket extension let me put all the plugs out of the site.
The wires hide easy behind the trim.
The fuse box is on the passenger side cover correct?
putting the cig lighter fuse into that b position makes power constant 24/7, as opposed to A setting which turns power on with ignition.
Another route that works is accessing the fuse box on the driver side inside the car, test all the unused slots and find which one is constant, then run a wire straight into that fuse and slap a 2.5 or 5amp fuse on that unused slot.
