E-Class (W211) 2003-2009
Drivers side speakers don’t work
Old Mar 9, 2018 | 10:19 PM
Angelfire's Avatar
2007 E350
As the title says, I noticed today when using my AUX port that my driver side speakers don’t work. When I did some googling, people say it could be the amp or the audio gateway. Are they the same thing or two different models? If they are different, how do I tell which is faulty? I have a 2007 E350. Thanks!
Old Mar 10, 2018 | 06:57 PM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
If this condition is only with the auxiliary connection I would check the cable your using first to validate it isn't the source.
Old Mar 11, 2018 | 04:30 PM
konigstiger's Avatar
'71 Pinto
If all else is fine including connecting cable as suggested previously and malfunction is restricted to AUX check wiring harness (part # 2115409910 viewed here https://www.ecstuning.com/b-genuine-...ss/2115409910/) connecting the head unit and the Aux Jack located in the glove box. If fine have someone check for fault codes using MB DAS (diagnostics) before replacing parts.
