E-Class (W211) 2003-2009
TPMS: Any special mounting considerations?
Old May 21, 2004 | 12:04 PM
NuBenz's Avatar
02 996 C2 Cabrio
I may be dealing with a flat, non-repairable tire, and I have the tire pressure monitoring system (TPMS).
Here are my Q's:
1. Is the TPMS sensor/mechanism located in the valve stem assembly? Or, is it a belt style system wrapped around the inside of the rim?
2. Are there any special considerations for re-mounting a tire on a rim with the TPMS? Meaning, do sensors have to be reset somehow with the car's computer?
I'm probably going to swap out all the tires at a non-dealer location. The Continental ContiTouring Contact CH95s are a P.O.S.!
They're far too soft. The car bounces all over the place. The ContiSportContact 2s on my last car were far superior.
TIA and cheers!
Old May 21, 2004 | 01:32 PM
awiner's Avatar
2003 CL55 AMG
TPMS is integrated in the valve stem. On the inside of the rim there is a small box attached to the valve stem that relays the signals.
Read you manual. It will tell you how to preform a reset.
Old May 21, 2004 | 10:49 PM
NuBenz's Avatar
02 996 C2 Cabrio
awiner,
Thanks for the info. I do know how to reset the TPMS via the display options. I was wondering if re-mounting a tire would affect the sensors in any way, since I didn't fully understand the location and structure of the TPMS.
I actually had the tire properly patched from the inside out. DARN SCREW!
I saw the TPMS sensor on the back of the valve stem when the tire was off the rim. Re-mounting the tires didn't adversely affect the sensors at all.
It was only $23 to patch, re-mount, and balance... I guess I'll be forced to stick with these tires a little longer... :p
