E-Class (W211) 2003-2009
rough idle
Old May 21, 2004 | 12:49 PM
redlands40's Avatar
E500
rough idle
is there a thread that covers rough idle,its not that bad, but on a 55k car it does not seem right.
Old May 21, 2004 | 12:51 PM
BMcD-E500's Avatar
2013 GL550
Did you recently fill up with gas? You may have gotten a bad tank of gas. Had that happen on my S4. Fresh gas from a different place - problem solved. Hopefully that's the easy fix!
Bruce
Old May 21, 2004 | 12:57 PM
redlands40's Avatar
E500
no its not gas, i have had the car 3 month, and its been the same since i owned it, and i use different gas station, as i said its not bad, but you can certainly feel it
Old May 21, 2004 | 03:32 PM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
Originally posted by redlands40
no its not gas, i ahve had the car 3 month, and its been the same since i owned it, and i use different gas station, as i said its not bad, but you can certainly feel it
Is your gas filler cap securely fitted? Could be drawing in air if not "clicked" properly.
Old May 21, 2004 | 03:38 PM
redlands40's Avatar
E500
yes it clicks
Old May 21, 2004 | 03:39 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
[QUOTE]Originally posted by redlands40
no its not gas, i ahve had the car 3 month, and its been the same since i owned it, and i use different gas station, as i said its not bad, but you can certainly feel it [/QUOTE
First, your throttle stop may be not be normalized. From the car being off, insert the key and urn your ignition key to position 2 and wait at least 90 seconds (without starting the car). I usually wait two minutes. See if this helps. Usually the throttle stop not being normalized can cause wandering idle, not rough idle. If this doesn't help, then...
Ask the dealership to perform a flywheel adaptation. The ME settings (such as phase of spark timing) can be out if the battery goes dead or from other situations.
-s-
Old May 21, 2004 | 03:43 PM
redlands40's Avatar
E500
thanks for the info will try it and let you know, is a problem you have heard before many time, or just isolated cases
