E-Class (W211) 2003-2009
E500 air suspension
Old May 11, 2018 | 06:26 AM
Khalintf's Avatar
2003 Mercedes Benz E500
E500 air suspension
I have a 2003 Mercedes Benz e500 sport. My air suspension on the driver side rear has a bad leak and it goes down off and on. I also have a 2007 Mercedes Benz e320 I was wondering if I can use that air suspension strut on my e500 Mercedes Benz?
Old May 11, 2018 | 08:01 AM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
Does your e320 have airmatic? Useally its the airbag that leakes and not the sturt. You need to check the parts number to see if its the same trough WIS.
Wis/epc is mercedes own parts and workshop program and you can buy it for your home computer for around 20 isd on ebay. Its very good.
Depeding on how long your going to have the car you can either buy used airmatic components trough ebay or arnott replacement units. Bilstein have airmatic as well.
check out www.arnotteurope.com.
most replace oem with arnott components.
If you have common tools you can replace them yourself with the help of wis.
Old May 19, 2018 | 12:35 AM
Carcheologist's Avatar
2010 ML350 Bluetec, Alfa Romeo GTV6
I believe they are the same, but check with Arnott or another site to find out for sure.
I did an air spring replacement on our e320 wagon recently and it wasn't that bad. I used the Arnott air springs.
