E-Class (W211) 2003-2009
Differential Oil Question
Old 05-12-2018, 02:09 AM
superfast's Avatar
97 Lexus LS400, 04 Mustang, 08 Corvette Z51, 92 Honda Civic Si, 02 CL500, 03 E500
I have an 03 E500 & thinking about changing the differential oil. The manual called out 1.34 qts of 85W90 but I have plenty of 80W90. Is 85w90 thicker at start up? Would like to know which weight do you guys normally use? Thanks.
Old 05-12-2018, 10:23 AM
Veteran: Army
Plutoe's Avatar
Received 1,056 Likes on 977 Posts
1999 E300TD
If the vehicle is a town car you should have no difficulty using 80W vs 85W and yes as you lower the prefix number the viscosity changes, in your case thiner
superfast (05-12-2018)
Quick Reply: Differential Oil Question
