E-Class (W211) 2003-2009
unbolting rear suspension links
Old May 15, 2018 | 12:06 AM
scott099's Avatar
E500
whats the recommended way to unbolt the rear suspension links? I'm having a terrible time with them. the only one I have loose so far is on the back (sorry I forget the name of it, but uses a 10mm hex bit) that one came out ok, and the sway bar link. I tried messing with the top one and couldn't get it to budge
Old May 15, 2018 | 12:12 AM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Are you referring to the arms that go to the frame?
Old May 15, 2018 | 12:38 AM
scott099's Avatar
E500
where they attached to the knuckle (wheel carrier) side
Old May 15, 2018 | 12:51 AM
Agent-A01's Avatar
There's nothing special, same principle applies for most suspension parts; they are torqued really good and if they have never been undone before, they usually have some corrosion on threads..
You may soak what you can with krano kroil(best penetrating oil you can get, much better than pblaster or similiar)
Lastly, if you are using two ratches, make sure both are set to loosen and not one loosen and one tighten(I've seen DIYers make that mistake before and wonder why they aren't making progress )
Old May 15, 2018 | 02:34 PM
scott099's Avatar
E500
Thanks! I was able to get them unbolted. I only had PB blasted laying around but it did the trick. took quite a few tries with the 1/2 impact but eventually it came out. the very top one was by far the worst. now I'm trying to get the axle to pop out and having no luck with that lol!
