2008 mb e350 best spark plugs
I Just bought a 2008 mb e350 70 k and just doing some preventative maintenance what are the best spark plugs?
Next up tray fluid changs and cabin air filter.
2016 E350 4Matic; 2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
I prefer the NGK over Bosch as the terminal nut end is solid (as fitted OE) rather than the generic Bosch nut that is open. The ignition coil contact, rather than around the edge of the Bosch terminal nut, has more contact surface with a solid top with the NGK.
I bought the Bosch from FCP, experienced a less than smooth idle, put the old ones back in until I can swap them for the NGK. NGK was fitted OE.
