E-Class (W211) 2003-2009
2004 E500 Hesitation when stopping
Old Jun 8, 2018 | 01:35 PM
Chris Downing's Avatar
2004 E500 / 2005 CLK 320 / 2010 YUKON DENALI
HI everyone, I need some help. I have a 2004 E500 130k. It recently started hesitating when I come to a stop and most recently it cut off when I took a turn into my driveway. It's not pulling a code and it doesnt do it all the time. I don't think the plugs or coil packs have been changed but I didn't want to start throwing parts at it. The mass airflow sensor was recently replaced. How would I know if it's a failing throttle body?
thank you
Old Jul 18, 2020 | 06:46 PM
adoomie's Avatar
w211 e500
You ever find the issue? I have a similar issue. I've replaced spark plugs, coil packs, MAF sensor to no avail.
Only ever had one code come on (cylinder 1 misfire) and most recently the MAF SENSOR which I replaced. Still have the same issue. I have fuel injectors on their way, can't really think of what else it could be.
Old Aug 17, 2020 | 06:14 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Could be the EGR Valve opening or closing when it's not supposed to. MY E500 had some hesitation and a few misfires for awhile and just finally threw a code for the EGR Valve, albeit intermittent even at 180K miles on the original. New one is on order under $100 USD.
