W211 Wiper stalk circuit
I’ve had some issues with the wipers before. They stopped working, couldn’t find the problem but started working normally a couple months later and now have stopped again.
is there anything I’m missing that needs to be checked?
http://www.mercedesmedic.com/fuses-w...-2008-e-class/
Which relay is it as there isn’t anything about the wipers in the fuse/relay booklet?
9050–communication with component m6/1 (wiper motor) is interrupted
9052– component m6/1 is blocked
9053– component m6/1 is defective
Any recommendations on a place to buy a good working unit on the cheap? I’ve never had a wiper motor fail in a car, but the procedure for replacement seems simple enough so at least I can fix it myself.
if anyone has the part number available—to shop on eBay— that would also be highly appreciated so I don’t have to take things apart before I have the replacement ready.
Was hoping it wasn't the SAM or even the switch which the wire can be located and fixed with a few good hours of fiddling about....
Found this thread and went to check the relay as its called "Relay - P Terminal 15R relay" - Not really a clue that its anything to do with the wiper/washer functions! Thanks MB.
Anyway, relay on my newly acquired 2008 E350 Sport was - AWOL, who knows who bothered to remove and never replace.
Got a regular relay and removed the 87a center pin to make it a 4 PIN relay to test and everything appears to be working just fine.
Must remember to get the right MB relay and replace...
Wiper/Washer functions - Relay P
Relay/Fuse Infor from -- https://fuse-box.info/mercedes-benz/...uses-and-relay
So thanks for the Thread.
Cheers.
Last edited by Mer1in; Sep 12, 2023 at 06:16 PM. Reason: Add link for fuse/Relay Info
