P0401 EGR fault but engine lite is still on
On my W211 (2005) Mercedes, I had an EGR fault with P0401 and engine light on. I've bought a new EGR and fitted into the car and for first it was all fine however later the next day the engine light came back on. I am not sure what else to check.
I also have a boom boom sound when car is driving but I cannot identify what it is.
Last problem is, while the car is driving it gives judder
Please help.
Kindedst regards
J.
If not one of these and it probably is the list gets pretty grim pretty fast from my experience. I would get an MBII if you don't already have one.
Try taking off the engine oil cap while the engine is on if its under pressure you have a vacuum leak at the very least. Insufficient (too rich or lean) oxygen ratios in regards to combustion can cause engine knock/misfires. Take a look at your spark plugs, then maybe consider Sea Foam but not before you rule out everything else. Seafoam is effective but controversial to say the least among benz owners.
2527 - Check component Y27/9 (Left EGR positioned) signal wire open circuit
2025 - Check component B28/5 (Pressure sensor downstream of air cleaner) The signal voltage is too low
2355 - Check system Exhaust gas recirculating control The air mass is too large
2089 - Check component B60 (Exhaust back pressure sensor ) Voltage is too low.
I already bought and got the exhaust pipe (original from Mercedes) replaced but the above was coming while new EGR was in place. So we replaced the original one in and the car did exactly the same.
kindest regards
J.
