E-Class (W211) 2003-2009
Front Cup Holders in '04 E
Old Jun 6, 2004 | 05:31 PM
Barry45RPM's Avatar
2015 ML 350
The manual states they should be removed periodically from the front console to be cleaned, but nowhere does it say how to do that. Where you you pull from, is there a "release" latch? I don't want to break it just to see how to clean it... Thanks
Old Jun 6, 2004 | 07:39 PM
marksatex's Avatar
04' E500 w/Appear. PKG, Panorama Roof
Sounds like the perfect opportunity to "Stump the dealer"
Old Jun 6, 2004 | 11:44 PM
bmms8's Avatar
MB
i remember doing this a couple of times. when you take it out, it may seem hard, but keep in mind its harder to put back on for some reason. it isnt easy, but if you look in the day time, you will be able to see how to get it out. there arent any latches iirc. you might have to open it to take it out also, GL. if you need more help, ill check it out for you tomarrow. GL
