need spark plug torque for 2012 e350 M276
1) I should ONLY use MB spark plug?
2) Video I saw mentioned spark plug "Alignment" or bad things happen. Will Torque it self cause proper alignment?
3) What is Torque for 2012 e350 M276 - or where can I find these answers.
Usually Bosch, NKG, or Denso.
On the box it says the torque (18 ft. lbs. )
Use a torque wrench.
What do you mean by spark plug alignment?
I have seen videos about "lining up" spark plugs to increase performance, but not required.
https://www.youtube.com/watch?v=EiRAnh_wEjg
is where I heard about "indexing the Spark Plug"
Between (40 seconds - 2 minutes ) they talk about tips/tricks/TSBs
Does this make sense?
This video makes an incredibly easy task incredibly difficult.
I have never, ever heard of indexing being required as the author suggested.
First, read a little about indexing to get some context, it is controversial:
https://www.fordmuscle.com/archives/2000/07/indexplugs/
Also, see how simply a spark plug change is:
http://www.mercedesmedic.com/spark-plug-diy/
The author of the video even takes out the car's CPU to change the spark plugs. WTF.
Plus, he uses a $600 torque wrench.
My digital torque wrench was less than $50.
Some videos are incredibly helpful on the internet, others not so much.
This was the worst DIY video I have ever seen, and I have seen a lot.
Does anyone disagree?
If I am incorrect I would truly like to know.
Also it mentions you might need to replace the 6 intake gaskets - YES or just reuse ?
You don't have to remove the plenum, but if you do, you can re-use the gaskets, just pull them from the upper part and put them on the lower half before you re-install.
