E-Class (W211) 2003-2009
Check oil level alert
Old Oct 1, 2018 | 10:57 PM
07BlackWidow's Avatar
2007 E350
So I changed my oil 7-3-2018 and just recently I keep getting the alert to check oil level when refueling. Every time I check the oil level is ok. It reads just a little over the full line. Is that why it's keeps alerting me cause it's barely over the full line? Or is there something else wrong? Any help would be greatly appreciated!
Old Oct 2, 2018 | 01:20 AM
95viper's Avatar
2007 cls550
Post a pic and ensure that it is seated properly before pulling out. I’ve read before where someone was reading the stick wrong.
Old Oct 6, 2018 | 09:21 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
You can also read the oil level on the dash display. The vehicle engine should be warmed up and the vehicle sitting on a level surface. Turn the engine off, wait a minute or so to let the oil level stabilize then turn the key back to the on position without starting the engine. The rest of the procedure involves holding the trip reset /dimmer light button It's not a laboratory calibrated reading but I've found it to be close if your oil level detector is functioning correctly..
Some videos that show how to do it
Old Oct 7, 2018 | 12:41 PM
ot1's Avatar
ot1
2006 E320 CDI
I am thinking it’s too full, because when you put when you fill the tank it could tip the car backwards slightly which could cause and over fill code. There is an oil fill threshold, which the oil level must be maintained within.
Old Oct 7, 2018 | 02:37 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
x2 on overfill.
