E-Class (W211) 2003-2009
Rear Shock Replacement Question
Old Oct 3, 2018 | 12:45 PM
lkchris's Avatar
'10 CL550, '12 GL550
My Son's 2005 E320 (600 miles away) has conventional suspension.
Rear shock replacement seems easy enough, but my question is can I obtain enough clearance jacking the car with floor jack at the rear jack point to enable removal/installation of the shock, or does the car need to be on a lift?
Old Oct 3, 2018 | 12:52 PM
05w211wagon's Avatar
2005 e500 w211 wagon
everything is easier with a lift, but using a jack and stands you should be just fine.
Old Oct 4, 2018 | 02:10 PM
LexBrett2's Avatar
2007 Mercedes E550
I'm doing my rear shocks right now, and although I am using my lift, this definitely could be done with some good jack stands.
