05 E500 failed front driveshaft.
I will definitely be checking my 04 E320 wagons front driveshaft now
I know MB sells whole shafts only.
Here is a link I saved in the past, but I never used them. http://www.driveshaftspecialist.com/.../Mercedes.html
I always advise to check 4M driveline on regural basis.
Torn boot on CV can be DIY for about $80, but if you neglect it, the only available new MB shaft is $1300. (you still can go Chinese for less)
Any vibration calls for immediate inspection. We had member who was pushing the front shaft job and the thing snapped on his driveway, with all side bags exploding. Had to be some impact.
I will definitely be checking all driveshafts and joints now though. We have 4 4Matics and only one has had driveshaft work done
I definitely will be checking u joints on all other vehicles.
only had 150k on the e500 when this happened.
i highly recommend that anyone with a 4matic check their front driveshaft, and even replace it as preventative maintenance
