E-Class (W211) 2003-2009
Transmission Removal write-up?
Old Nov 22, 2018 | 12:52 PM
LBe320's Avatar
E320
In my quest to resolve all oil leaks, is there a write up on how to drop the transmission? So far, I have done the valve covers, oil level sensor, transmission plug (and conductor plate in the process)... I haven't seen anything on the front leaking, but it's definitely still leaking somewhere in the front where I can't see because the front of the oil pan has some wet spots, and the rear main seal plastic covers have oil slowly coming out of there as well. I'm going to hit the dipstick O-ring as well. Thanks!
Old Nov 22, 2018 | 01:18 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Old Nov 22, 2018 | 02:42 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I would tend to say "If you have to ask, maybe you'd be better taking it to professionals".
The job is easy when you have lift, jacks and so on. There is not much technical difficulties, but access to top bolts that require long extensions and swivel sockets.
Old Nov 23, 2018 | 07:09 PM
realeric's Avatar
W205 C300, W212 E350, Q50
Lifting the car would be the most important thing. Put strong/sturdy jig under the tires. You will need minimum 20” clearance under the car. Two floor jacks will be needed to support the transmission.
Old Nov 24, 2018 | 11:15 AM
LBe320's Avatar
E320
Thanks for the tips. I have a set of quickjacks, I think it'll be high enough to drop the tranny.
