E-Class (W211) 2003-2009
W211 Left Mirror Repair
Old Dec 1, 2018 | 06:25 PM
sphell's Avatar
2007 Mercedes E350 Avantgarde
I noticed the other day the up/down adjustment stopped working on my left side mirror. This meant that it didn't tilt down anymore when I was reverse parking and it's a feature I love because I can make sure I don't bash my rim into the gutter!
The left/right adjustment still worked fine it was just the up/down. I guessed it would probably be the mirror motor so I pulled it apart and tried Googling part numbers, however there was nothing available locally. Mercedes wanted something stupid like $500 just for the motor assembly!! For the meantime I swapped the up/down motor with the left/right motor so the reverse tilt works.
Here are a few pics of the mirror internals. I measured the voltage on the terminals and as you can see it's just a 12V motor and the polarity is reversed to make it go the other way.
Mirror with glass removed showing motor assembly.
One of the two motors inside the motor housing assembly. They are both the same in the left mirror. Motors are made by Johnson but I couldn't find anything online with this part number.
Multimeter hooked up to left mirror to check voltage driving the motor assembly.
12V driving the motor assembly
12V reversed to drive it the opposite way
Motor assembly removed from left mirror. This part is $500 from Mercedes in Australia! Many like this online but they are all slightly different. Unless the yellow part number is an exact match, it's different in some way.
Motor assembly pulled apart and two motors removed. In my case one motor is faulty and has stopped working.
Just by chance I looked at aliexpress.com and found a little motor that has the EXACT measurements of the factory mirror motors. I just searched for "Mercedes mirror motor" and it popped up for $4US!
So I've ordered two and will post an update when they arrive - fingers crossed they fit and fix the problem!
Motor I found on Aliexpress.com
Old Dec 2, 2018 | 09:17 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Keep us updated and good on ya for having the wherewithal to take things apart instead of just throwing money at it!
Old Dec 3, 2018 | 10:14 AM
ot1's Avatar
ot1
2006 E320 CDI
Getting that helical off might be a trick without damaging it
was the motor coil open?
Old Mar 15, 2019 | 02:52 AM
sphell's Avatar
So 3 months later the mirror motors arrived!! Long story short, they sent the wrong ones, then I had to wait for them to re-send the correct ones because it was Chinese new year and they were on holidays....I'd given up hope but then the other day a small package arrived in the mail and lo and behold......
The replacement motors were exactly the same size as the factory ones. I pulled the worm drive off the factory motor and pressed it onto the replacement motor and clicked it into the motor housing. It works fine, the only difference is that it's noisier than the factory motor.
I'm happy, mirror fixed for a couple of dollars.
Here's a few pics.
The replacement motors.
Motor housing disassembled.
Chinese made motor next to factory Mercedes one.
New motor in housing. Fits perfectly.
Old Aug 10, 2019 | 01:50 PM
Kebowers47's Avatar
001 s600, 94 sl600
Your RV mirror motor purchase from alliexpress is FANTASTIC. Can you PM me with the details. I would appreciate it greatly and will somehow post it in the forums to share the GREAT FIND.
kebowers47@gmail.com
832-651-7576
Old Aug 11, 2019 | 07:20 AM
sphell's Avatar
832-651-7576
Here is the link to the mirror motors
https://www.aliexpress.com/item/3291...4f984c4dv5A4TU
Old Aug 12, 2019 | 02:07 PM
Putbinoot's Avatar
E320 cdi
Thanks for this, my mirror motor fault is the exact same so have ordered the motors, does the glass just pull of to let you get to the unit. Thanks for any help.
Old Aug 12, 2019 | 02:51 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 12, 2019 | 03:37 PM
Putbinoot's Avatar
E320 cdi
See attachments.
thanks for that.
Old Mar 16, 2023 | 10:10 PM
ET2000's Avatar
2008 W211 E300 4Matic
Originally Posted by Putbinoot
thanks for that.
Did you do it? Seems I have the same issue. Please let me know.
Old Apr 6, 2023 | 01:18 PM
ET2000's Avatar
Here's a few pics.
I know this is old, but I've just tried it but couldn't disassemble the motor, the plate on top was impossible to move without breaking. Any tips ?
