W211 Undervoltage charge battery fault
w211
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/660x1280/48403654_366838804066137_5961501970777767936_n_fb30a4977eef60e216c55d622f6ec7ef94638101.jpg)
Hello, new guy here. So i have this fault. Changed my main battery, fault still remains. No info online about this error? Any help?
Received 1,492 Likes
How old is the battery and what's the voltage on the battery? Sound like what it says it is, you may have a dead cell and the voltage is probably below 11 volts. Maybe be time for a new battery. You could also go to an auto parts store and get the battery load tested.
w211
You didn't answer the question. What's the voltage? Even new batteries can have dead cells and sometimes the dead cells don't show up until you get it load tested.
Received 1,736 Likes
1922 Ford Model T / no OBD
That error coming with engine running is charging issue, not battery issue.
How old are alternator brushes?
w211
w211
12.7V at idle is bad. Get at least new VR .
Is it really -30 Celsius where you're at? 12.7 seems high when it's that cold. Did you check it with a meter? I'd also get it load tested. Mine drops as low as 11.5 volts when it's at 20 degrees Fahrenheit. You normally get a low voltage message when it drops below 11 volts. which I could see happening at -30.
w211
It's in the picture.
Well I suggest you get it load tested. Your best case scenario is a bad battery. Otherwise it's going to take some trouble shooting to find the problem.
You should also measure the voltage with a meter when you get that error message.
w211
ok.. its funny. First. This error popped up on the used battery i used for 2 years and it was used before, because i bought the car with it. I changed the battery couple days ago and issue remains. U say my new battery is bad?
If you're lucky, then it's just the battery, new batteries also go bad if they're sitting on the shelf too long or you just picked a bad one. Otherwise you have some odd electrical problem that someone will need to actually troubleshoot.
I also find it hard to believe that you have a 12.7 reading when it's -3 outside and the battery is under load connected to the car. Check your connections.
w211
I asked for the voltage of the battery when it's connected to the car when you get that error message. You can easily get 12.7 volts with no load, but once loaded, the voltage will drop. You only find out about a bad cell when the battery is under load, which is why I keep suggesting to get it load tested.
w211
I don't think you know what no load means. No load is when the battery is not connected to the car and has been at rest for a little while. If you check the voltage right when you disconnect the battery from the charger, it will be higher than if you wait a couple hours. The car always has some items on like the clock, alarm system, bluetooth, etc. Therefore when it's connected, it's under load. The battery is typically an 80-90 amp hour battery. You just need to charge it til it reaches 12.7 volts at 70 degrees. With a 10 amp charger on a dead battery, that should take a little more than 8-9 hours as you have line losses and it's not a direct 100% charge. Normally with a battery that's slightly discharged, it won't take nearly that long. Of course if you just have a 2 amp charger, it will take a lot longer. When I've connected a fully charged battery to the car, it read 12.3 volts and that was at 70 degrees. I get a reading as low as 11.5 volts when it's 20 degrees Fahrenheit outside. That's why when you claim it's 12.7 volts and the temperature is -3 C, I find it hard to believe. That's why I asked for the voltage of the battery when you got that message. Either it's below 11 volts and the car is fine, or if it's above 11 volts, you have some other issue with the car. Just basic trouble shooting 101. I still feel like you haven't really given me the answer yet.
w211
Is that the voltage in the display or did you check it with a meter? Anyway, sounds like you have some other more complex problem. You either need to dig up a wiring diagram to troubleshoot it or get it scanned and see if there are any MB specific error codes.
w211
w211
quick update. I was charging the battery for about 6hrs. Plugged it in checked the voltage its 12,8v. Turned the car on, got some load. Displays 13,5v.
When you get it load tested at an auto parts store, they put a 100-200 amp load on the battery and they see how well it recovers. If it passes the load test, then you have some other strange problem which you could try trouble shooting by getting the car scanned for MB specific trouble codes.
