faulty trans or TC
2004 E320 Wagon
faulty trans or TC
Hi. I recently towed my 2004 E320 a long way. This is because it broke down during a long drive from home. MB dealer there said they couldn't find the problem. Turned out to be a bad battery only. So, having towed it back and spent ages trying to get it to run again (for some reason the computers needed resetting. It now does run fine. However, it no longer goes into gear. Could the trans have been damaged from the tow? I cant understand why it worked before the tow and not now. Can anyone offer any suggestions. Thank you.
Received 1,744 Likes
1922 Ford Model T / no OBD
Did you have it on flatbed?
MB never allows towing with wheels on the ground.
That might be exaggeration for short tows, but suppose with engine off- transmission pump is not pumping oil on the bearings.
I guess there is 1 way to find out.
Looks like you have 5G transmission.
On benzworld forum you will find member handle MAVA.
He is expert indy in those transmission and posted thousands advises about them already. Since those transmission were installed in several different models, the info is spread between the sections, but it is all out there.
Good luck
Good luck
